Author: Subject: ZX7r Carb Problems
oliwb
posted on 16/2/06 at 06:52 PM Reply With Quote
ZX7r Carb Problems
Ok having finally got a manifold sorted and my megajolt up and well sparking! I need to get the car started...one problem with that! Attached it all up today with the pump and everything and there seems to be no petrol entering the engine! Can make the engine run purely on easi-start but revs the nuts out of it! I've got a small inline filter before the pump and a big one before the carbs. When i turn the ignition on the pump does its stuff and half fills the filter then cuts out.....there is fuel in the bowls though as I removed one....so can't understand why there would be fuel in the bowl but not entering the engine!? If anyone can enlighten me I'd be much obliged! Its on a 1.6 pinto by the way......cheers Oli.
froggy
posted on 16/2/06 at 07:17 PM Reply With Quote
have you done any mods to the carbs before fitting them? ie drilled the main jet and raised the needle etc.?
stevec
posted on 16/2/06 at 10:51 PM Reply With Quote
havnt some of the Kawasaki carbs got fuel cut off valves on the carbs, could they need energizing?
