Avoneer
posted on 15/3/06 at 08:54 PM |
Blade Header Nut Size
Are they 5mm x 1.5 (fine) thread?
Pat...
Andy W
posted on 15/3/06 at 08:59 PM |
std pitch for 5mm is .8mm
Lightning
posted on 15/3/06 at 09:08 PM |
I recon Chris is right.
Gav
posted on 15/3/06 at 09:37 PM |
Pat, if you manage to find some, let me know
Avoneer
posted on 15/3/06 at 09:45 PM |
M7 - that's what I meant .
Chris, where did you get 8mm by 8mm studs from?
Gav, will let you know and get you some as well - oh, also got a Cat you can borrow for SVA - see my post in Engines & Transmission.
Pat...
posted on 15/3/06 at 09:51 PM |
Buy a length of 8mm threaded bar and cut your own, it's only about 75p a metre at our bolt shop. Lock two nuts together to install them. put a
nut on before you cut it then dress the end thread before you take the nut off and it will clean it up as you remove it.
[Edited on 15/3/06 by Peteff]
Avoneer
posted on 15/3/06 at 10:16 PM |
Aaahhh, never knew they were normal 8mm into the block.
Will get some normal studs and normal nuts (and extras for Gav).
Pat...
Gav
posted on 15/3/06 at 10:22 PM |
That would be much appreciated Pat!
let me know the cost and ill PP it across.
And yes id be very interested in hiring your CAT eventually!
Avoneer
posted on 15/3/06 at 10:31 PM |
Nuts and studs will be free mate.
Cat will as well to you
Pat...
Gav
posted on 15/3/06 at 10:59 PM |
Cheers Pat, much appreciated!
