Author: Subject: blade 919 wiring
ch1ll1
posted on 7/9/06 at 08:04 PM Reply With Quote
blade 919 wiring
hi all
what wires do i have to short out to get the baby turning over?
(BEING LAZY REALY)
its an old 97/98 lump
any help would be great
cheers paul
[Edited on 7/9/06 by ch1ll1]
ChrisGamlin
posted on 7/9/06 at 08:24 PM Reply With Quote
Some of them
/also being really lazy
ch1ll1
posted on 7/9/06 at 09:03 PM Reply With Quote
i have found the side stand switch,( i hope )
is there a clutch switch?
not got a wiring diagram yet
ChrisGamlin
posted on 7/9/06 at 09:07 PM Reply With Quote
It was a very long time ago when I did mine so I can't remember off the top of my head, but I did write a quick document at the time detailing what needed chopping / changing so I'll see if I can dig it out.
ChrisGamlin
posted on 7/9/06 at 09:14 PM Reply With Quote
Here you go
• Ensure the chassis is earthed to the negative battery terminal
• Ensure all Green wires in the loom are earthed to the chassis
• Connect Green and Green/White together at the side-stand switch connector
• Connect Green/White and Green/Red together at the clutch switch connector
• Earth the Blue/Red neutral switch wire (Unless you always want to find neutral before starting it!)
If you don’t have the original handlebar switches:
• Connect a switch between Black and Black/White for the stop switch. Leave switch in “open” position until ready to start.
• Connect a switch between Red/Yellow and Black/White for the starter switch. Leave switch in “open” position until ready to start.
• Connect up the instruments, ignition control module, regulator, coil packs etc. The only connections that aren’t generally needed to fire up are ones relating to lights, horn etc.
• Check all the fuses in the fuse box.
• If you have a post ’97 engine then you might have a pink wire going into the ignition barrel connector. If there is, this is the immobiliser circuit and if you don’t have the original bike ignition barrel (which has the resistor built in), you will need to connect a +ve feed to it with a 390ohm resister in line to supply the correct voltage to the ECU so it will start.
• Connect up the battery. Turn on the ignition, put the Stop Switch so that it is making a contact (closed), then press the starter button and she should fire
This was for a 98/99 engine, the 97 engine doesnt have the pink wire and might generally be slightly different, but as Ive never modded an earlier loom, I don't know for certain.
HTH
[Edited on 7/9/06 by ChrisGamlin]
ch1ll1
posted on 8/9/06 at 07:02 AM Reply With Quote
Cheers for the reply
