Author: Subject: ZX9/E mis-fire problems FIXED
gizz
posted on 26/5/03 at 05:26 PM Reply With Quote
The diagnosis and theory in my previous email was 98% correct it was fuel starvation in the manner I thought; however it wasn't fuel draining back to the tank that was the problem, it was a lack of 12Vdc at the pump. Pillock!!!!. Yes these engines run without the pump running!!! The engine suction isn't powerful enough which is why Kwak fit a nice little electric pump. I had connected the the blue and black fuel pump supply to an incorrect feed. Simple.
Thanks for the reply from Jasper, his problem sounds like sticking pilot jets.
£20 spent at the local bike centre will get them cleaned and should cure the problem.
MK9R
posted on 26/5/03 at 06:09 PM Reply With Quote
Good to here you sorted it. I was goping to suggest the same to Jasper about the pilot jets.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Jasper
posted on 27/5/03 at 10:47 AM Reply With Quote
Good one Gizz, and thanks for the feedback.
Jasper
posted on 28/5/03 at 07:16 PM Reply With Quote
Gizz
Turned out I had the same problem as you. We're I had wired up my emobiliser it stopped the fuel pump running, so now it's sorted and running loverly.
