andyd
posted on 31/5/03 at 08:40 PM |
Stuart Taylor exhaust on a Luego 'blade
Anyone care to comment on whether you think a Stuart Taylor exhaust system for a Fireblade would fit a Luego chassis.
The reason I query it is that I believe that the ST cross member goes the opposite way to the Luego one at the point which the exhaust exits the side
panel. I don't want to take the chance and cough over £300 and find it doesn't fit although I'm sure one of you guys would buy it
off me for the same money so I'm not out of pocket.
Anyone?
MK9R
posted on 3/6/03 at 06:59 AM |
No help at all for this question, but just thought i tell you that the Tiger racing ZX9R exhaust doesn't fit the MK very well. We are going to
have to do a bit of extra bending and cutting. The engine in the tiger must sit at slightly different angle and be a little higher in the chassis. The
exhausts front pipe is just touching the bracing tube, the collector is not horizontal and is sitting slight;y below the the chassis. It doesn't
need much modifying but needs it to get it perefct.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
westindy
posted on 4/6/03 at 09:12 PM |
ST Exhaust - ZX9R
I used a ST system on my Indy, its works fine but you need to mount the engine in conjuction with fitting the exhaust system so that the front pipe
misses the diagonal - a good buy at £300 + drat
