Author: Subject: syc fireblade carbs
mkblade
posted on 21/2/08 at 12:18 AM Reply With Quote
syc fireblade carbs
nearly their now i hope all the carbs are now back on everything connected,ive even connected the balance pipes ready to syc the carbs at weekend.
got another couple of questions done a serch didnt bring up any answers
1 there are 3 air screws to balance the four carbs anyone one got a pic so they can be pointed out to me?
2 i want to leave the take of pipes that ive screwed into the carb port holes will need to blamk them of somehow anysuggestions i thought some vac pipe with a small bolt in the end ??
3 using the standard air box high flow filter i have pulled out the two air trumpet pipes from the airbox to allow more cold air to get into the airbox is this ok ?
thanks once again
simon
worX
posted on 21/2/08 at 12:24 AM Reply With Quote
1. I'll have a look for a pic for you now, but not sure on that one!
2. You just need to join the stainless turned spigots together with your vac' pipe - join them 1+2 and 3+4. No need to use the bolted/blocked off ends.
3. That is fine to remove them, but you may want to consider ducting air directly into them. I have a spare piece of ducting (concertina(sp) type) air hose if you need it?
