Author: Subject: Diameter of R1 intank fuel pump
stuart_g
posted on 14/3/08 at 01:58 PM Reply With Quote
Can someone tell me what size hole is needed in the tank to fit an R1 in tank pump.
Also the outer diameter of the mounting flange on the pump itself.
It is for an '05 engine but I think all the injection pumps are the same.
Stu.
Johneturbo
posted on 14/3/08 at 03:42 PM Reply With Quote
Are you changing your set up Stu?
soz, i can't help with the sizes
stuart_g
posted on 14/3/08 at 06:36 PM Reply With Quote
I am looking into fitting the R1 in tank pump instead of the external Bosch pump. More for simplicity really as the Bosch pump takes up a lot of room and the pipe runs to the tank look like there going to have to be quite long when a filter is fitted. The pipes will then have to be held up out of the way.
It would be easier to fit the R1 pump in the tank and have one pipe from that to my copper pipe feeding the injector rail.
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 14/3/08 at 06:39 PM Reply With Quote
Stu
You'll still need a return that goes back to the pump i believe.
Will measure tomorrow for you.
stuart_g
posted on 14/3/08 at 08:05 PM Reply With Quote
I have the return pipe going to the tank. I was just going to block the return off at the pump.
