Author: Subject: Oil level light? Baffle plate?
adithorp
posted on 2/5/08 at 08:13 PM Reply With Quote
On my 5vy R1when I start up everything is fine, all lights out and loads of oil presure. Then after its run for a couple of minutes the oil level light comes on, still plenty of presure and oil in the sight glass (1/3 down). Then when it gets hot, out goes the light!
Happens every time.
So here's my theory... the oil isn't draining back through the baffle quick enough when its cold and the level in the sump drops just enough to trigger the light (with the angle of the engine in the fury the sensor is higher than normal). Then when its hot the thiner oil flows back fine.
So, given that I don't intend to thrash it when cold everything should be OK...right?
adrian
[Edited on 8/6/08 by adithorp]
grub
posted on 2/5/08 at 08:48 PM Reply With Quote
mine is the same i take it you have a baffle plate in i think its just as you say
adithorp
posted on 2/5/08 at 08:58 PM Reply With Quote
Yep, got baffle plate in and slight overfill.
Cheers, feel happier knowing its not just mine.
Here's another one... after running stationary for a while in the workshop the engine warning light comes on. I get code 42 which is no speed sensor reading. Move the car and out it goes. Glitch in the programing?...getting confused when stationary for too long?
adrian
welderman
posted on 2/5/08 at 09:31 PM Reply With Quote
not an answer Adrian, but what day is the big day next week.
Joe
Thank's, Joe
I don't stalk people
adithorp
posted on 3/5/08 at 07:28 AM Reply With Quote
Who told you my birthday was next Saturday?
...oh, you mean SVA day. Test is on Monday the 12th. 10 days and counting...and running out of jobs to do.
adrian
stuart_g
posted on 17/5/08 at 01:22 PM Reply With Quote
I have exactly the same happen to mine. does this matter and will it be worse out on the road. Surely if the oil level light is coming on then the oil pickup isn't going to pick any oil up and could lead to dry bearings.
BTW Did your car pass SVA?
adithorp
posted on 17/5/08 at 05:05 PM Reply With Quote
Well it seems ok once the oil warms up. Think it gets back through the sump baffle better then. The oit level sensor is higher than standard the way I've got the engine mounted so comes on earlier. When its on I've loads of oil presure.
Failed the sva on emmisions and noise. Think I've sored it now and got the retest booked for the 27th. Hopefully I'll get a cancellation and get it done sooner.
adrian
adithorp
posted on 8/6/08 at 05:13 PM Reply With Quote
Well after a week/350miles it seems Ok once warm...untill it's at either continuous highish revs (7500 on moterway) or giving it welly. Then the oil level light comes on after a couple of mins. Pressure is good. Ease off and it goes out after 30 seconds or so.
I think the oil just isn't getting back through the baffle quick enough. The level is high in the sight glass when the light is on. So the question is...
Do I...
A. Remove the little butterfly bits from the holes in the baffle.
B. Drill some more holes in it.
C. Do both A+B
adrian
adithorp
posted on 9/6/08 at 09:47 AM Reply With Quote
Is that Tumbleweed blowing past?
adrian
progers
posted on 9/6/08 at 10:40 AM Reply With Quote
Hi Adrian,
I would be tempted to enlarge the existing drain holes and try to "swage" the hole such that the oil is encourage to drain back into the sump.
This is what I did with by R1 baffles (for 98-03 engines) and I have never seen any issues with oil lights coming on. The fact that you see it is worrying. I personally do not like the little "butterfly" openings on the baffles that fluke motorsport sell (I presume you have one of these).
Regards
Paul
