Wheels244
| posted on 18/5/08 at 08:41 PM |
Barnett Clutch - Supplier
Does anyone know the best\cheapest place to buy a Barnett clutch for a 5PW R1 ?
I'm nearly at the point of firing it up and want to put one in before I put everything else in the way.
What's the best set up ? extra spring, friction plates etc...
trikerneil
| posted on 18/5/08 at 08:59 PM |
I got my Barnett bits from PDQ. LINKY.
Have a look at their listing HERE.
HTH
Neil
ACE Cafe - Just say No.
nitram38
| posted on 18/5/08 at 09:12 PM |
There are lots of people who say just change the springs, but I have changed the whole clutch.
The barnett plates have a larger surface area so the springs have to be stronger to create the same pressure over a wider area.
I haven't run mine yet so not sure if it is any better.
My own guess is that it should last longer due to the spread load.
I got mine on ebay for £90 delivered about 10 months ago.
Johneturbo
| posted on 18/5/08 at 09:31 PM |
What effect would just changing the springs have, would it give more feel?
nitram38
| posted on 18/5/08 at 09:37 PM |
It increases the presure on the standard clutch plates so there will be less slip.
If you want a better feel then you will need to increase the length of the clutch arm so that it gives the correct pedal travel.
A lot of people have just a short pedal with a bolt/stop so that they cannot break the clutch arm by going to far.
For me a long pedal with a biting point is better than an off or on pedal.
Everyone to there own preference, but a longer pedal should be much easier on your foot in traffic on the uk roads.
Check out my photo archive for my wilwood set up with diagrams and measurements. I am using the wilwood pedal box too.
[Edited on 18/5/2008 by nitram38]
Johneturbo
| posted on 18/5/08 at 10:02 PM |
Ok, think i just need to get use to it, the little bit of driving i've done, i've found it doesn't like lots of revs on pull
away.the lower the better. the clutch travel/pivot is just the right amount.
worX
| posted on 19/5/08 at 09:04 AM |
Take a look at the Clutch replacement requirements in your R1 manual. Measure the thickness of the plates (friction and steel) and compare to service
tolerances and then go from there.
From personal experience I wouldn't change from OE plates, but would def do Barnett Springs, so if your plates are OK you'll save a few
quid... If not, I would still buy OEM Stuff.
quote: Originally posted by Wheels244
Does anyone know the bestcheapest place to buy a Barnett clutch for a 5PW R1 ?
ChrisGamlin
| posted on 19/5/08 at 07:22 PM |
Dont forget with the 5PW (and earlier), its not simply a case of buying stronger springs because the earlier R1 engines use a diaphragm spring rather
than a set of coil springs like most bike clutches.
IMHO you'd be better off buying the Barnett spring conversion kit which includes a new pressure plate etc, and then using the standard plates,
even using the existing ones in there if they're OK.
The spring conversion kit is the BEC alternative to putting in an additional diaphragm spring, its more expensive but does give a better clutch feel.
Stock clutch plates are absolutely fine though, I kept the original (4000 mile old) clutch plates that came with my 5PW engine and they're still
in there now nearly 3000 miles /10 trackdays / 3 years later.
Wheels244
| posted on 10/6/08 at 08:53 PM |
Thanks Chris - is this the 6 coil spring conversion ? How much did you pay for it and where from ?
Anybody else done\used anything different ?
eccsmk
| posted on 10/6/08 at 09:16 PM |
maybe here but ive not checked so could be wrong
ChrisGamlin
| posted on 10/6/08 at 09:40 PM |
Yep its the 6 spring conversion, I think I got mine from Graeme at Fluke Motorsport, but its the same one
as at the bottom of the PDQ link above. I think at the time it was about £100 all in but that was nearly 3 years ago.
pic from Fluke website.
[Edited on 10/6/08 by ChrisGamlin]
Wheels244
| posted on 10/6/08 at 09:52 PM |
I've just read Fluke's fitting guide.
It says don't fit the race springs go for the road ones and some people put a washer on each spring for extra feel - did you do this ?
What's the feel like ? Much improved over standard ?
ChrisGamlin
| posted on 10/6/08 at 10:03 PM |
I fitted the race springs and didnt have any problems, I think on some installs the springs can just start to bind so if the clutch plates are new it
might not quite disengage. My friction plates were the original ones in the engine though, so that may help.
As to the feel, Im not sure really as I fitted it when I installed the engine so can't compare, but everyone else thats fitted one afterwards
say its an improvement. To me its a vast improvement over my old 919 blade clutch, much more progressive and useable in traffic.
progers
| posted on 11/6/08 at 09:15 AM |
Regarding the fluke fitting guide, I think this was done at the time when the "race" springs did indeed bind so it was better to use the
road springs. I used the road spring with an additional washer underneath and it worked well.
I have subsequently bought another Barnett conversion for my spare engine. I noticed that the "race" springs are different now (they are
black) and do not bind like before. They work fine.
Like Chris, I would recommend you use the OEM plates. I only used Barnett Kevlar plates once and they did not last long before slipping. I have had 1
1/2 seasons of racing out of my current OEM set and they are still going strong :-)
Paul
P.S. I have two original (as new) Yamaha diaphram springs that people can have (for doubling up your existing spring). Anyone who wants one just give
me a shout and they can have them for £5 each incl P+P.
progers
[Edited on 11/6/08 by progers]
Wheels244
| posted on 11/6/08 at 09:05 PM |
Chris \ Paul
Thanks very much for the info.
I'll order the conversion this week.
I'll stick with the OEM plates as you suggest.
Can't beat personal recommendations
Cheers lads
Rob
