001Ben
| posted on 17/8/08 at 04:49 PM |
5JJ Cable
Does anyone know where the Blue with black trace from the ECU goes?
The ecu is a 2000 - 2001 5JJ US version without the cycle locks. According to mr haynes it goes up to the ignition control switch but I am not too
sure if it needs connecting somewhere to allow the car to start, however the car is turning over. The wire has +5V on it. Originally I thought it
went to the blue/yellow cable from the clutch but this already has 12V on it from the starter circuit relay.
Replaced the relay assembly and ecu and I now have 0V on the blue and yellow - the car is still turning over etc as before but not still not
starting.
[Edited on 17/8/08 by 001Ben]
adithorp
| posted on 17/8/08 at 05:20 PM |
It goes to the ignition switch and connects to the blue with yellow tracer that goes to the start relay and clutch switch. Secondary ignition
circuit.
adrian
http://jpsc.org.uk/forum/
001Ben
| posted on 17/8/08 at 05:55 PM |
excellent I have wired that in but i'm still not getting a spark , what else could it be?
It currently is:
In neutral
clutch bypassed
side stand bypassed
stop switch bypassed
Anything im missing?
001Ben
| posted on 17/8/08 at 06:21 PM |
would it matter if the exup was not connected?
adithorp
| posted on 17/8/08 at 07:20 PM |
Exup won't effect it. The others stop the starter turning (clutch switch will cut ignition when you put it in gear).
Whats your ingnition/starter switch setup?
adrian
001Ben
| posted on 17/8/08 at 08:07 PM |
Thanks Adrian - i now have a spark. The pick up coil wasnt pushed in fully, doh!!! with all the testing and the problems with the ecu i must of left
it slightly out, however it wont start now because the battery is on the rather low side
