Author: Subject: Powercomander help.
Jason Fletcher
posted on 22/9/08 at 08:40 PM Reply With Quote
Powercomander help.
Guys
When you get the matrix of numbers up on the laptop is it a case of adjusting every one individually or is there a way of adjusting a bigger band in one go?
What do the three buttons do on the front?
Tried the importers and they are awful! Never phone back and if woe betide you if you get the chick with the attitude!
adithorp
posted on 22/9/08 at 08:57 PM Reply With Quote
You can left click and highlight a block of fields and change them all.
The 3 buttons allow you to change the fueling accross a rev range (low, medium or high). Hold all 3 down and switch on the ignition. Then select the range to alter. The lights on the left will toggle up and down as you press. To choose a new range start again. (think thats right)
adrian
http://jpsc.org.uk/forum/
