Author: Subject: I need an extended gear lever arm for my Busa but where from?
Jason Fletcher
posted on 26/9/08 at 09:10 PM Reply With Quote
I am fitting a gear shifter on my busa and I need a longer gear selector arm (the splined one that bolts to the selector shaft on the engine)so I can get the throws correct. Does anyone know how many splines the thing has and where I can get one from?
cheers
jason
[Edited on 30/9/08 by Jason Fletcher]
Simon
posted on 27/9/08 at 10:52 AM Reply With Quote
Can't you make one - then you can get the size spot on.
You can count the splines quite easily
Simon
Jon Ison
posted on 27/9/08 at 11:21 AM Reply With Quote
I'm sure others do them but I get my "splined" bit from MK then just weld on whatever arm I want/need.
Jason Fletcher
posted on 27/9/08 at 08:12 PM Reply With Quote
Simon
the std one is cast so to keep it looking proper then its not just a case of welding a bit on the end and although my workshop is not badly equipped I do not have the broach needed to cut the splines.
Jon
thanks for letting me know who sells the splined bits, I'll call them Monday
cheers
Jason
