Author: Subject: fireblade carb adjustment
phil m
posted on 27/9/08 at 01:16 PM Reply With Quote
just doing the pre-sva set up and the fuel / air ratio needs adjusting.
Is it a case of tweaking each adjuster screw the same amount until I get the right reading?
mad-butcher
posted on 27/9/08 at 04:19 PM Reply With Quote
If you're talking about balancing the carbs then you balance them against the base carb ,for the life of me I can't remember but I think it's number 2, there's some genuine honda blade manuals on my site
link
are you using vacuum gauges
Tony
[Edited on 27/9/08 by mad-butcher]
phil m
posted on 28/9/08 at 11:02 AM Reply With Quote
Thanks Tony
Managed to balance them --it's the fuel air mixture that I need to sort out for Lambda
