MK chippy
| posted on 26/10/08 at 11:37 PM |
R1 engine mounts
Hi guys.
Got my 07 R1 engine from yorks engines but didnt get the mounting bolts with it and was wondering what you guys had used to mount your engine? Also
have you mounted your engine in with rubber mounts or not?
sorry if this is a dumb question.
Dave
nitram38
| posted on 27/10/08 at 05:05 AM |
Solid mounts on your chassis are best. Thread is un-usual as it is a metric fine thread (someone will be along to tell you or do a search).
mad-butcher
| posted on 27/10/08 at 08:45 AM |
seem to remember an ad from andy AB. he has some had to buy them in 500's, send him a u2u
link
Tony
[Edited on 27/10/08 by mad-butcher]
Rob WM
| posted on 27/10/08 at 12:09 PM |
Afternoon
I used M10 threaded bar on the bottom mount and then M10 1.25 thread pattern on the top mounts for my R1 2006. On the MK the mounting brakets on the
top are different widths so check first I think the bolts were about 120 and 140 long though?!?!? I am sure someone will fill you in.
I got the bolts from a local fastening company, and I haven't used rubber mounts.
Hope this helps.
