Author: Subject: R1 long engine bolts...
StevieB
posted on 22/11/08 at 08:51 PM Reply With Quote
Evenin' all,
I need to find somewhere that can do me a couple of m10x280 bolts for my R1 engine.
So far, I've only found places that will sell be bulk boxes, which means I'll have 98 spare engine bolts and the 2 I use will have cost £27.50 each.
dmac
posted on 22/11/08 at 09:09 PM Reply With Quote
try your local Yamaha dealer, I got a complete set of engine bolts for less than £10.
Duncan
smart51
posted on 22/11/08 at 09:27 PM Reply With Quote
I used studding with a nyloc on each end. 3 years in and its been just fine.
dmac
posted on 22/11/08 at 09:31 PM Reply With Quote
Now that sounds like a proper locost solution!
StevieB
posted on 22/11/08 at 09:35 PM Reply With Quote
I've got threaded rod in there at the moment but I don't like it - with the engine vibration it's a bit like having a saw blade against the soft ali engine. This does not sit well in my mind.
I'm not sure if the orignal Yamaha bolts are long enough for the MK engine cradle. I'd be more than happy to find othrwise - keeps life nice and simple/cheap
dmac
posted on 22/11/08 at 09:56 PM Reply With Quote
My bolts are 220mm from under the bolt head to the end of the bolt (for an early carbed engine).
It seems to me that its a poor design of cradle if it won't accept the original bolts.
You could always get some plain rod and thread the ends for nuts.
Duncan
[Edited on 22/11/08 by dmac]
jambo
posted on 23/11/08 at 12:57 AM Reply With Quote
get a bit of 10mm bar and thread your own to suit,
much stronger than chocolate threaded rod.
i used threaded bar before and it snaped in uses such as this.
smart51
posted on 23/11/08 at 08:32 AM Reply With Quote
The bar goes through one engine mount, through the engine, then through the other engine mount. It is clamped up tight. There will be no movement of the bolt through the engine. Engine vibration will shake the whole car on its suspension springs but won't move the bolts.
