corrado vr6
| posted on 1/2/09 at 11:59 PM |
Polo rad Fan size
Hi
Im thinking of using a polo rad for my 06 R1 but unsure as to what size fan to get any recommendations and wheres best place to get one, i see CBS do
a range but ebay seem cheaper just need to know what size for a VW302 rad
Cheers Greg
vinny1275
| posted on 2/2/09 at 08:04 AM |
Hi Greg,
I got one of CBS' fans, a 12" one. The feet supplied with it didn't quite reach the mounts on the rad, so I made a couple of plates
for them to sit on (21x6 cm) - there's a photo on my blog if you want to take a look.
HTH
Vince
Norledge
| posted on 2/2/09 at 09:54 AM |
I've always used Pacet Thinline fans...
http://www.pacet.co.uk/thinline.htm
Not the cheapest around, but certainly do the trick!
I was running a 10 inch fan on the Honda with the standard 1.3 Car engine, so i'd imagine it'd be fine for a BEC...
They mount on cable tie sort of things that your run through the fins too
www.built4track.co.uk - cheap track days and the like!
James
| posted on 2/2/09 at 11:00 AM |
Although take care with that type of mounts as (as has been discussed here before) the cable tie can 'saw' through the rad!
If you use these mounts then make sure you fit the rubber covers on the cable tie to protect the rad.
James
- Muhammad Ali
omega0684
| posted on 2/2/09 at 11:16 AM |
10 or 12" ideally
corrado vr6
| posted on 2/2/09 at 12:16 PM |
Thanks guys, Think ill go for a 12" fan then, another question i assume i will need a fan switch what temp switch should i be looking at for my
06 R1 in an MK Indy thanks again
Greg
SPYDER
| posted on 2/2/09 at 10:05 PM |
Hi there. We have used two Aprilia RSV fans on our Polo radded Phoenix Fireblade. Paid £10 for one and £8 for the other. Each one around 7".
They are made by SPAL and suck like fury!
Fan mount is custom made.
Geoff.
[img] [/img]
