Author: Subject: clutch judder ???
tootall
posted on 21/2/09 at 10:52 PM Reply With Quote
clutch judder ???
i have just got my gsxr1000 powered indy ready for sva. and i took it up my privat lane today and when i set off i sliped the clutch fine drove in first gear for 100 meters with clutch right out then stoped then whent to set off again and it wouldnt slip just judderd and bit really hard . its done this befor once its going its fine when u stop and try it again its fine ?? is this common traite of a bec or is my clutch not happy
some people dream of sucsess, others just get on and do it !!
Steve Hignett
posted on 21/2/09 at 10:58 PM Reply With Quote
Could be a broken spring?
tootall
posted on 21/2/09 at 11:02 PM Reply With Quote
i have a friend who use to do drag racing hyabusas and he said its just what they do as it happened alot with his bike on the line
posted on 21/2/09 at 11:14 PM Reply With Quote
Could also be the discs are a bit rusty if the engine has been sitting for a while. It may sort itself out given time.....
posted on 21/2/09 at 11:19 PM Reply With Quote
I have to say I've NEVER felt our's judder on take up.
Is there too little or too much Oil in there?
posted on 21/2/09 at 11:20 PM Reply With Quote
omega0684
posted on 21/2/09 at 11:31 PM Reply With Quote
is it a case of you just being a little too cautious and not giving it enough umph!
jimgiblett
posted on 22/2/09 at 09:36 AM Reply With Quote
Sounds like you have toasted your clutch steels. Whip out the plates and see if they are very blued. Lay then on a piece of glass to check for any runnout.
Sportsbike clutches will suffer more from this than tourers (all be they high performance ones like in a Busa or ZX12).
- Jim
dean100yz
posted on 22/2/09 at 01:51 PM Reply With Quote
If your basket is grooved you can find when you use the clutch you get that judder feeling.
From what Ive seen what your saying sounds quite commen although the amount it judders can very between BECS.
When I first got mine I took the clutch case off to inspect it. Found my steels had blued has mentioned earlier and the spings had grooved the basket. I filled the basket to make it really smooth and replaced the plates also using fresh 10w/40 semi synth.
Its much better but still does it a little. Hope that helps?
