Author: Subject: Power Commander map for '05 R1 with Pipercross airbox needed
Gergely
posted on 24/2/09 at 09:26 AM Reply With Quote
Hi!
Is there anyone with the same setup as us? We have a '05 R1 engine with Pipercross airbox and MNR 4-1 straight exhaust with no cat. Does anyone have a map for this setup that could send it to us?
Otherwise would you suggest just using a non-cat, straight through race can bike map available on the Power Commander page as a start?
Thanks a lot!!
Gergely
Our build pictures
antonio
posted on 24/2/09 at 04:00 PM Reply With Quote
hope that helps:
http://tournay.free.fr/PC/03-1.htm
cheers
if you need some to translate, give a shout
Gergely
posted on 24/2/09 at 05:17 PM Reply With Quote
Non, ca va, merci antonio!
But the problem is, it still only talks about bikes, hence is not exactly the setup we have.
If No-one has the same setup as we do, then I will go for a non-cat open exhaust map and that should be fairly close...
Merci!
Gergely
Our build pictures
antonio
posted on 24/2/09 at 07:58 PM Reply With Quote
a trip from hungary to uk may be great!!
cheers
Kosmo
posted on 24/2/09 at 08:54 PM Reply With Quote
Sorry to hijack the post but I need the same map.... same set-up on my car.
Anyone got soemthing I can start with ?
Kosmo
