macspeedy
| posted on 11/3/09 at 04:49 PM |
wanted: a different reverse gear for electric reverse
We have a kit we aquired for electric reverse but the big gear in the prop fouls a water pipe clip, are there people out there that have these sorts
of things in stock?
| posted on 11/3/09 at 04:52 PM |
the ring gear is often a modified engine part but if I was you I'd just move the clip!! You usually have to get the ring gear machined and
drilled to suit the new use you are putting it to and that means some seriously hefty machinery. My brother had to get a ring gear machined for his
home brew reverse mech and the first machine shop that tried to machine it managed to break their industrial lathe trying to do so.....
IE no to off the shelf parts
macspeedy
| posted on 11/3/09 at 05:51 PM |
thing is i cant move the clip, it is where it is is, its not the bolt part..
rb968
| posted on 11/3/09 at 08:47 PM |
I've been looking into this at the moment. Chap at work in our machine shop appeared with a catalog for this firm.
http://www.hpcgears.com/products/spur_gears.htm
I was trying to match a ring gear to a ZX9 starter which turned out to be an odd tooth pitch so was expensive. But they do a huge range of DP and
sizes. Seemed happy to take a on an odd job though as long as they had the tooling to cut. Worth a call.
Am now off to the scrappy to find a smallish car starter as need it to engage/disengage as the bike starter is always pre-engaged and thats not
ideal.
Rich
motorcycle_mayhem
| posted on 12/3/09 at 09:10 AM |
I moved the chassis uprights at the rear of the tunnel to get some electric reverse stuff in, to have just moved a clip would have been a Godsend.
Breath deep and relocate?
macspeedy
| posted on 12/3/09 at 12:05 PM |
Its all part of the same thing, i cant move the pipe or the clip, its all on the engine! new gear perhaps...
