Author: Subject: where to put a heater in the plumbing ??
macspeedy
posted on 20/3/09 at 08:54 PM Reply With Quote
I am getting the bits together for the cooling system on the zx12 install and was wondering where people recon the best place to put the heater / demister system. ie between water pump out and oil cooler or between pump feed and pump... ??
Mac
blakep82
posted on 20/3/09 at 09:18 PM Reply With Quote
i think theres normally 2 take off points on the cylinder head isn't there?
________________________
smart51
posted on 20/3/09 at 09:50 PM Reply With Quote
My heater is taken off between the head and the thermostat. The return tees into the pipe from the rad to the water pump, which feeds cool water into the engine.
Paul TigerB6
posted on 21/3/09 at 09:19 AM Reply With Quote
This is the BEC section......... surely you cant be allowed to say such blasphemous things as "adding a heater / demister" to your lightweight car in this section!!
macspeedy
posted on 21/3/09 at 11:46 AM Reply With Quote
I have 2 outs from the engine block, one goes to the oil cooler the other goes to the water pump. will i get enough flow, or could i possibley interrupt a necessary flow ?
Mac
