Author: Subject: Ooops...
richard thomas
posted on 2/6/09 at 02:16 PM Reply With Quote
Ooops...
Decided to drive car into work today - gearshift started to feel a bit woolly on the way in.....got into car park to find that the gear stick itself has started to shear at the weld where it meets the cross tube in the tunnel....hope that it'll last to get me home again or it could be a run home in 2nd
Mr Whippy
posted on 2/6/09 at 02:34 PM Reply With Quote
just don't tell anyone at work or you'll never live it down if it comes off
paul the 6th
posted on 2/6/09 at 03:05 PM Reply With Quote
my knob dropped off once... right bloody farce
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
Dangle_kt
posted on 2/6/09 at 03:13 PM Reply With Quote
Is your last name Bobbit?
Humbug
posted on 2/6/09 at 03:33 PM Reply With Quote
happened to me once ("gear" knob, thank you very much!). I had a Westy where the gear stick had been cut off and rewelded at an angle, It broke at the weld, leaving about an inch of stick. Luckily the box was nice and smooth, so I managed to drive home OK.
afj
posted on 2/6/09 at 03:43 PM Reply With Quote
HAPPENED TO ME ON SUNDAY my knob came off in my hand ...i thank you
eerrrrrrrrrrrrrrrr
richard thomas
posted on 3/6/09 at 11:20 AM Reply With Quote
Just made it, but had to do a lot of stirring to find some gears - found that you can pull away in 3rd....
dean100yz
posted on 3/6/09 at 01:02 PM Reply With Quote
Same happened to me after Id had it about a month
Gear linkage felt like you said then it went in 2nd.
Got it home and had it welded much stronger
easisatman
posted on 3/6/09 at 09:14 PM Reply With Quote
seems a common problem I had my car for a couple of months when I was out just driving into a petrol satation -as you do when you have a bec. just changing down and hey presto gear knob and lever in my hand but not attached anywhere else!!! drove straight out of the petrol station and drove home in 3rd.
the lever broke at the bottom where the thread starts.
still easi fix re threaded lever and got the old bit out with an easi out!!
good luck with your fix
Paul
tootall
posted on 4/6/09 at 11:40 AM Reply With Quote
mine did it the second day on rd last week been out all day givin it some pain lots of gear changes and went out on my own later on at nigh and it snapped off at 12000 going into 3rd but gave me a false neutral thought id killed gear box till i lifted bonnet and touched broken leaver and it popped into 3rd phew
well least it will pull away in 3rd and still brake the speedllimit
some people dream of sucsess, others just get on and do it !!
