subk2002
| posted on 15/3/04 at 07:27 PM |
What's best diff setup??
Hi guys what is the best diff/rear brake setup for an R1 indy ??
| posted on 16/3/04 at 12:33 PM |
As you're building an MK Indy, I assume you are limited to Sierra (without having to do alterations) In which case it depends whether you want
limited slip or not. If you do, then there ain't a great deal of choice XR4x4 or XR4i with ratio of 3.62 to 1. If you don't want limited
slip, you have more choice and if you don't mind making small alterations to MK's chassis, the sky is the limit.
It all depends on what you want really. Top end speed or quick acceleration. If you search, you may be able to find a spreadsheet detailing various
alternatives. Or someone could post a link to it................
Whatever you want
ned
| posted on 16/3/04 at 12:36 PM |
3.38 is good, the lower the better for a bec. Bear in mind if you want to play about you could always put the lsd from a 3.62 or 3.92 into a 3.38.
Ned.
beware, I've got yellow skin
subk2002
| posted on 16/3/04 at 07:44 PM |
Dont want to do any alterations.
Is it better to have an LSD or not what are you using hellfire?
Is it better to have drums or discs ?
Mk-Ninja
| posted on 16/3/04 at 09:50 PM |
Diff wise you are better off with 3.38 for general use 3.62 for performance. LSD is always an advantage but more pronounced on the track. Drums are
lighter and easier to set up. Discs if you want the looks but are heavier.
HTH Gordon
I'm sure I've got one, just don't know where I've put it
loafersmate
| posted on 16/3/04 at 11:15 PM |
Well I'm running a 3.92:1 diff and it goes like stink up to 110 which is quite fast enough for the road in my book, brake wise discs will
require twin master cylinders with bias bar or pressure limiter to get the correct brake split front to rear at SVA........much simpler to just go
drum....still stops on a ha'penny!
Ben
| posted on 17/3/04 at 12:38 AM |
LSD is heavier...
LSD gives better traction on roads in't wet apparently.
LSD means you can do perfect donuts... allegedly!
'sup to you - we're running LSD
Heard a few negatives from track guys about 'em but...
