bigfoot4616
| posted on 23/8/09 at 07:10 PM |
blade clutch springs
was going to swop my old clutch springs into the new engine as i had been told they where uprated. i then discovered they where about 7mm shorter than
the springs in the replacement engine.
shouldn't they be the same length, just harder to compress?
carpmart
| posted on 23/8/09 at 07:48 PM |
Blade engine clutch springs vary in length from engine year to year. You need to buy the uprated springs specific to your engine.
[Edited on 23/8/09 by carpmart]
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
mark chandler
| posted on 23/8/09 at 08:12 PM |
Just harder to compress, look for thicker wire, if really heavy they may be shorter to ensure that they do not become coil bound.
That said my barnet upgraded springs are both longer and thicker than three standard blade engines that these have now been through.
Regards Mark
bigfoot4616
| posted on 23/8/09 at 09:52 PM |
both engines are the same year, 98.
both springs look the same thickness wire, just a different length
