Author: Subject: BEC clucth
roadrunner
posted on 14/10/09 at 01:42 PM Reply With Quote
BEC clucth
I've had a slipping problem on my zx9r clutch since last year(still not sorted yet i know), i did'nt know whether it was the springs i fitted which i now understand are crappy, or if it's the ware on the plate,s.
Now it only slips when given her the beans on up-shifts mainly clutchless. Yesterday i found that if i make sure the clutch is fully engaged before pressing throttle i get no slip at all. Does this mean it's the springs or the plates.
Thanks, Brad.
[Edited on 14/10/09 by roadrunner]
MK9R
posted on 14/10/09 at 01:53 PM Reply With Quote
Thanks, Brad.
what oil are you using?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
roadrunner
posted on 14/10/09 at 01:55 PM Reply With Quote
Castrol semisythentic i think. I know it's the right stuff.
MK9R
posted on 14/10/09 at 02:01 PM Reply With Quote
i'd replace the springs if it goes away nice cheap easy fix, if it persists change the plates and you will already have the new springs.
Cheers Austen
RGB car number 9
www.trackace.co.uk
roadrunner
posted on 14/10/09 at 02:04 PM Reply With Quote
Is there a quick easy way of checking the plates for ware.
MK9R
posted on 14/10/09 at 02:12 PM Reply With Quote
measure the thickness of them. Although a fellow racer did this and they were within tolerances and it still slipped like f***
Cheers Austen
RGB car number 9
www.trackace.co.uk
MK9R
posted on 14/10/09 at 02:13 PM Reply With Quote
Have you checked the clutch is fully engaging, i.e. is the clutch arm fully returning, i.e. is cable too tight?
Cheers Austen
RGB car number 9
www.trackace.co.uk
roadrunner
posted on 14/10/09 at 02:20 PM Reply With Quote
Yes , it was the first thing to check and also to make sure your foot leaves the clutch pedal alone.
