Author: Subject: Sanity check.. 2003 R1, clutch fitting / oil
Major Stare
posted on 6/12/09 at 09:52 PM Reply With Quote
Today i fitted the Barnett clutch to my 2003 R1.
Removed old clutch.
Put spindle behind Barnet plate.
Fitted long springs, tightened bolts.
Pulled clutch arm and fitted cover
Tighten cover
Checked clutch movement.
Now heres the thing....
I have tried the clutch and engaged gear, it feels no different than before.
Is this normal before i fill the engine with oil? ? ?
Jon "FISH"
imp paul
posted on 6/12/09 at 10:01 PM Reply With Quote
you should leave new plates in oil over night and then fit with new springs it mite feel like the clutch is a wee bit stronger to pull if new springs are uprated and yes put new oil in hope all is ok for you
ReMan
posted on 6/12/09 at 10:35 PM Reply With Quote
Doubt you'd really feel the difference under a size 9.
Trust that it will make the difference
spdpug98
posted on 7/12/09 at 09:39 AM Reply With Quote
Just done the same in mine, and to be honest it hasn't really changed that much (pressure wise with my foot) but now have no clutch slip and much better pickup
My Blog: http://spdpug98.wordpress.com/
Major Stare
posted on 8/12/09 at 07:33 AM Reply With Quote
When the clutch plate is bolted back, is it right that the clutch plates are clamped very tight together........
.... you might have gathered that im new to bike engines
Jon "FISH"
ReMan
posted on 8/12/09 at 08:49 PM Reply With Quote
Yes, if I understand the question correctly.
As per the feeling any differnt, if it feels much the same you have done it right
ReMan
Major Stare
posted on 8/12/09 at 09:07 PM Reply With Quote
Jon "FISH"
