Author: Subject: ZX12 Engine Mounts
twybrow
posted on 19/1/10 at 09:48 AM Reply With Quote
ZX12 Engine Mounts
Can anyone confirm that the 2000-2001 ZX12R uses the same engine mounts as the later models? Ie will an engine cradle from one year fit both?
Thanks chaps and chapesses.
minitici
posted on 19/1/10 at 09:50 AM Reply With Quote
I think the early ZX12R used two front mounts and the later used a single central front mount.
eznfrank
posted on 19/1/10 at 09:56 AM Reply With Quote
Above is correct
yorkshire-engines
posted on 19/1/10 at 05:26 PM Reply With Quote
Hi the a series zx12 2000 2001 are same rear mounts as the b series 2002 onwards the front mounts are different early ones have 2 mounts above 1 and 4 exhaust port the later have a single above 2 and 3 ports but BEWARE kawasaki are always registering early bikes on late reg numbers so always check engine not year of bike iv had 05 reg bikes that were really 00/01 reg with 00/01 engines in them
cheers malc
posted on 20/1/10 at 08:02 PM Reply With Quote
Malc,
are you sure they're 00/01 engines in 2005 frames? I thought they changed the ZX12R front mounts back to the original twin configuration in 2005.
Phil
rf900rush
posted on 21/1/10 at 07:14 AM Reply With Quote
I used a 00/01 front mount frame on my B model zx12 I just think the thread size was different,
