Author: Subject: Flatshifter
Jon Ison
posted on 14/3/10 at 08:45 PM Reply With Quote
Flatshifter
Retained the flatshifter used on the Blade and now ready to wire it into the Busa loom, trouble is I cant find the book anywhere.
Can someone who as instruction book tell me which colour wires to break into on the Busa ?
Ta.
sucksqueezebangblow
posted on 15/3/10 at 02:13 PM Reply With Quote
Hi Jon,
I've got the instruction manual for the Flatshifter Expert at home. I think the wiring will be the same except for the "cut" wires (it cuts injectors instead of spark). I'll dig it out tonight and try to remember to scan it for you tomorrow.
Jon Ison
posted on 15/3/10 at 10:12 PM Reply With Quote
if you would, would be very appreciated,
sucksqueezebangblow
posted on 16/3/10 at 01:11 PM Reply With Quote
Nipped home and got it this lunch time. I've got both; the Pro manual and the Expert manual. I assume you need the Pro.
Black = Battery negative or good chassis earth.
Brown = Switched +12 volts(from ignition switch or convenient switched live.
Blue = Ignition coil supply wire (ECU side)
Orange = Ignition coil supply wire (coil side)
Red and Red/Black = Red and Red/Black from Downshifter Control Box.
[img][/img]
Jon Ison
posted on 16/3/10 at 04:22 PM Reply With Quote
Thank you, locostbuilders at its best yet again.
Very much appreciated.
