| posted on 26/6/10 at 10:57 AM |
Using V-Twin Engines...
I quite like the idea of using a V-twin engine in a reverse-trike purely because of the power-delivery, but I'm a little conscious that with one
(large!) cylinder sitting almost vertically, then I could be compromising the all-important centre-of-gravity issue.
I'm thinking that an in-line four will have more of it's weight sitting forward in the car (and possibly lower).
Has anyone ever weighed a V-twin? I'm following a train of logic that says the V-twin engine must be heavier as the bikes they populate tend to
be heavier machines than their litre 4-cylinder competitors.
Any opinions?
It's Evolution Baby!
StevieB
| posted on 26/6/10 at 11:02 AM |
I thought of using a v-twin in my midget race car build.
My main concern wasn't so much the vertical height, as I think that's not too much different to a normal 4cyl motor, and you only have one
rather than 4 cylinders, so probably actually a better CoG. My main concern was more to do with the front cylinder sticking through the area where my
suspension would need to be.
smart51
boxer engines are good for low C of G. I guess that's why Grinnall use them. Scooter engines are the same. V twins are nice and narrow, which
is good for a single seater. How tall is the engine you're looking at? How high is the crank from the sump. An individual engine will have a
low C of G if the crank height and overall height are low.
On mine, I'm moving the battery and cooling right to the front to help improve weight distribution a little.
| posted on 26/6/10 at 11:25 AM |
Go the whole hog and fit a V4
There a ST1100 "trike" on youtube.
ali f27
| posted on 26/6/10 at 12:07 PM |
I fancy puting v max in my car anbody looked at it
| posted on 26/6/10 at 01:05 PM |
It will be going into a single-seater, but there is plenty room at the back for a 4-cyl.
Re. the Boxer engines. Are they not super-heavy?
| posted on 26/6/10 at 06:37 PM |
I know STM put a twin engine car in one of the locosts. It was certainly a Honda lump perhaps the SP1 if I recall correctly.
phelpsa
| posted on 26/6/10 at 07:24 PM |
The newer generation of BMW engines are lighter (the 1200 range), but still not great on the power to weight front. You also have to run a silly low
diff ratio (around 2:1) or massive wheels to get a reasonable top speed....
smart51
| posted on 26/6/10 at 07:53 PM |
quote: Originally posted by phelpsa
The newer generation of BMW engines ... have to run a silly low diff ratio (around 2:1) or massive wheels to get a reasonable top speed....
Except with a single rear wheel, you can use the same wheel and final drive as the donor bike
