Author: Subject: oil level
brookie
posted on 19/7/10 at 06:12 PM Reply With Quote
oil level
how do u check the oil level on the 919 blade engine then also are there know for oil leaks because mine got one and i dont now where it coming from
bigfoot4616
posted on 19/7/10 at 06:24 PM Reply With Quote
there is a sight glass, look at the bottom of the clutch cover. it is awkward to check the level, i use a torch and look through one of the suspension holes in the side panel.
not sure about likely places for leaks. best thing is to give it a good clean and then see if you can see where its coming from
mark chandler
posted on 19/7/10 at 06:47 PM Reply With Quote
Fill to the top of the sight glass, then overfill by 200mm, get to much in and the clutch will slip.
Not known for leaks, its a honda
daviep
posted on 19/7/10 at 06:52 PM Reply With Quote
Or possibly 200ml overfill it 200mm and it'll be coming out the filler hole
mark chandler
posted on 19/7/10 at 09:32 PM Reply With Quote
Opps 200ml it is
brookie
posted on 24/7/10 at 05:35 PM Reply With Quote
that must be when the engine is not running is it
gixermark
posted on 24/7/10 at 09:09 PM Reply With Quote
correct..
you can get a decent flexible inspection mirror from halofords that makes this easy - a torch to then shine onto the mirror surface makes it even better
