Author: Subject: jettting honda 919 blade
joni
posted on 6/8/10 at 12:43 PM Reply With Quote
hi lookin to no wot jets to use in bec 919 blade engine thanks jon
gingerprince
posted on 6/8/10 at 12:46 PM Reply With Quote
Depends entirely on your particular setup, e.g. your exhaust, inlet etc. There is no stock answer.
carpmart
posted on 6/8/10 at 12:53 PM Reply With Quote
As Mr Ginger says, its down to setting up the correct fueling for your car install as opposed to a generic answer!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
rgrs
posted on 6/8/10 at 12:57 PM Reply With Quote
Phone the blade expert:
andy at ab performance
linky ab performance
He will be able to point you in the right direction and also supply the jets.
Regards Roger
Andy B
posted on 6/8/10 at 02:57 PM Reply With Quote
Thanks for the plug Roger
assuming you are using the blade self regulating pump so that the carbs are behaving correctly as a starting point try
Mains 132
Air screws 21/2 turns out
Needles DJ FLTV 50
Lift springs DJ uprated
Air correctors - blocked
Give me a call on 01449 736633 if you need more info
best regards
