Author: Subject: Power Commander 3 switching maps R1 05
RickRick
posted on 16/4/11 at 09:23 PM Reply With Quote
After some help using my power commander
i belive that your able to set up 3 maps on the PC3 and switch between them on the unit
am i right if so how do you do it?
everytime i think i've surfed to the manual it's for pc4
adithorp
posted on 16/4/11 at 09:33 PM Reply With Quote
Not as standard, but there is an add on box that allows you to I seem to remember.
[Edited on 16/4/11 by adithorp]
http://jpsc.org.uk/forum/
SausageArm
posted on 17/4/11 at 06:12 PM Reply With Quote
I have a Power Commander 3 (USB) but mine also has the multi hub adaptor added to it which allows you to switch between maps, eg high/low boost, I wasn't aware you could switch between maps without it.
RickRick
posted on 17/4/11 at 07:08 PM Reply With Quote
well that might explain why i can't find anything on the powercommander website about it!
posted on 18/4/11 at 04:24 PM Reply With Quote
It should be easy enough to upload a new map from your laptop (assuming you have one) I can't think of any instances where you'd need a map that was instantly switchable (although I haven't thinked for long )
Phil
