Author: Subject: sh-t my 919 fire blade engine broken
brookie
posted on 20/4/11 at 08:11 PM Reply With Quote
as above i think i bent a valve on number 4 piston will now more after the weekend when i can strip it down
matt_gsxr
posted on 20/4/11 at 08:56 PM Reply With Quote
That is annoying, my cylinder head is on the kitchen table at the moment too!
A new valve is only about 15quid
Think of it as an opportunity to do a bit of a tidy up, to check the valves all seal nicely and to get the valves shimmed properly. Maybe a set of new valve seals too if you feel the urge.
brookie
posted on 21/4/11 at 06:24 PM Reply With Quote
it may not be as bad as i thought when the bloke put it back togeateher after stripping the head off a few week ago it look like he put the shims in wrong so it holding the number 4 valve open i hope so should be just a case of checking the shims are right
