noc231073
| posted on 10/6/11 at 08:22 AM |
Speedo sensor location hayabusa
Anyone know where the speedo sensor location on a gen 2 busa is I have check the manual and and it should be just to the right of the clutch slave
cyclinder but no am I missing a part of my engine where it covers the shaft where the drive shift coupling fits
It looks like I don't have the sensor there at all
[Edited on 10/6/11 by noc231073]
MikeFellows
| posted on 10/6/11 at 08:40 AM |
take a photo of yours and I will take one of mine
and you can compare
tomprescott
| posted on 10/6/11 at 09:47 AM |
and you can compare
That's disgusting! He only wanted to know about the speedo sensor location!
A bird in the hand....
cosmick
| posted on 10/6/11 at 09:03 PM |
Standard position for speedo drive on all Hayabusa's is sprocket cover. it is driven by the cross headed washer that goes over the front
sprocket. As a matter of interest, i use the standard speedo drive on my car taken off the 4 bolt heads at the front drive flange so it is in almost
the same position as the motorcycle.
If it can't be fixed with a hammer then its probably an electrical problem.
