tony.g
| posted on 4/11/11 at 09:47 AM |
919 Blade main bearing torque
Can any one tell me what the torque setting is for the main bearing on an RRX Blade engine.
Tony
PAUL FISHER
| posted on 4/11/11 at 12:09 PM |
You can download a fireblade manual from here free.
http://www.carlsalter.com/motorcycle-manuals.asp
tony.g
| posted on 4/11/11 at 04:32 PM |
Thanks for the reply, but i can't find it on there.
Every model but the one I want.
Tony
doddy
| posted on 4/11/11 at 05:45 PM |
in my book there all the same for early blades up to 1999
crankcase bolts 6mm 12 nm 9 ft-lbs 8mm 25 nm 18 ft-lb 9mm 35 nm 26 ft-lbs 10mm 39 nm 28 ft-lbs
connecting rod bearing cap nuts 34nm or 25 ft-lbs
hope that helps
https://www.ebay.co.uk/str/4x4wheels
tony.g
| posted on 6/11/11 at 01:30 PM |
Thanks.
Tony
