Author: Subject: CBR 1000 engine angle
locoboy
posted on 28/9/04 at 11:00 AM Reply With Quote
I am looking to find out what sort of angle i need to mount my CBR1000 motor at when its installed in the chassis. I want to keep it as close to the same angle as it was in the bike to avoid andy oil starvation problems.
EDIT: If you dont know the answer can anyone suggest a suitable place to find it - have googled it but only got answers concerning cornering angles and valve angles
Col
[Edited on 28/9/04 by colmaccoll]
Locoboy
jimgiblett
posted on 28/9/04 at 12:48 PM Reply With Quote
A friend of mine has a CBR1000 engined striker. Done quite a few trackdays without any sign of oil surge. IIRC his sump is parallel with the floor of the car.
Post a message on the BEC list for Luke he may be able to give some guidance.
Jim
locoboy
posted on 28/9/04 at 01:25 PM Reply With Quote
Cheers Jim,
When you say parallel with the floor do you mean its put in bolt upright?
Locoboy
Stu16v
posted on 28/9/04 at 07:00 PM Reply With Quote
Used to use a CBR 1000 in me grasser-fine motor (if a little heavy) ...
As Jim (sort of) says, when the engine is sat as per the bike, the sump base should be parallel to the floor.
HTH Stu.
locoboy
posted on 29/9/04 at 10:30 AM Reply With Quote
Thanks chaps, one less thing i need to worry about when im making the cradle.
Stu, i might be badgering you for a bit of help with sorting out what bits of various ancilliaries attach to where on my engine seeing as you have just admitted to having prior experience with them
Locoboy
Stu16v
posted on 29/9/04 at 06:12 PM Reply With Quote
No worries mate...
jimgiblett
posted on 30/9/04 at 11:32 AM Reply With Quote
I thought I was being as clear as ever
