number-1
posted on 23/4/13 at 06:14 PM |
whaddayareckon?
Folks, im getting nearer completing The Mook. Ive installed a new gear shift shaft as the teeth on the other one were shagged. Do you think i should
run a bolt through the gear change link/pivot into the small rose joint with spacers to keep the gear change cable straight, or just whack a bolt
through the gear change link/pivot into the rose joint without the spacers?
adithorp
posted on 23/4/13 at 07:01 PM |
I'd expect it to be pretty stiff if you put it at that angle. I'd go with the extension bolt idea as long as the bolt doesn't flex.
That'd give a poor feel to the change and possibly (long-term) result in the arm breaking.
Can you not bend the outer cable mount to give a better alignment?
http://jpsc.org.uk/forum/
number-1
posted on 23/4/13 at 07:04 PM |
Thats not a bad idea! It looks pretty beefy but i'll give it a try tomorrow.
