Author: Subject: exhausts lengths
GeoffB
posted on 21/6/05 at 08:20 PM Reply With Quote
exhausts lengths
does anybody know of any plans or dimensions for ablade engined mk, especially manifold and down pipes.......
or could someone measure the length of thier down pipes from the manifold to the collector..and any idea of diameters at the manifold
Lightning
posted on 21/6/05 at 09:11 PM Reply With Quote
Personally I would get a manifold that has equal length primarys, my Mk one doesn't. The car goes fine but I have a feeling that this could be the cause of my difficulty getting the noise level down. It is 101db even with a 6" box 24" long.
Rorty
posted on 22/6/05 at 04:16 AM Reply With Quote
I would definitely aim for primaries that are all the exact same length.
The diameter of the primaries will depend on what you want the car for and how you want it to perform.
Basically, longer and/or smaller bore pipes will increase low and mid-range torque (good for sprints and autocross), whereas shorter and/or larger bore pipes will help with higher revs (longer legs).
This page may be of some use to you: LINK.
Cheers, Rorty.
tks
posted on 23/6/05 at 04:11 PM Reply With Quote
mhh
i also messed with the exhaust lenghts and i did it all manual..
see my archive..
but don't have noise problems..
altough i use now (compared to original)
1 silencer per 2 cylinders
the noise is quet low only if you throlltle up it will make noise, and most of the noise comes out the air box..(stock elements)
grrrrrmm..
Tks
