Author: Subject: Help with engine set up!
Guinness
posted on 30/7/05 at 08:35 AM Reply With Quote
Right, finally got the battery fully charged, new plugs fitted, exhaust manfiold and silencer fitted, 5 litres of BP Ultimate in the tank, pump primed and ready to start the engine.
Checked water levels, oil level and it's in neutral and fired it up!
It runs but even with the choke fully in it seems to idle at 5000 rpm, which is way high. No tension on the throttle cable and adjusting the idle screw makes no difference.
Any ideas welcome.
Other than a mega idle speed seems to run OK, no leaks or anything!
Mike
marc n
posted on 30/7/05 at 08:39 AM Reply With Quote
sounds like an air leak of some kind round the induction area, or running very rich, have you done an emmisions test ????,
Guinness
posted on 30/7/05 at 08:55 AM Reply With Quote
Nothing that complex marc, but cheers for the response.
It was down to operator error. I had turned the idle adjuster the wrong way and it'd come loose. Fixed it now, happily ticking over at 1250rpm, temp guage up to 1/3rd and I chuffed to bits!!!!!!!
Now how do I post a video of this occassion??
Mike
Danozeman
posted on 30/7/05 at 09:16 AM Reply With Quote
Well done mate glad its sorted.
Dan
Ben_Copeland
posted on 30/7/05 at 09:27 AM Reply With Quote
well done mate.
Ben
Locost Map on Google Maps
Enter Your Details Here
Guinness
posted on 30/7/05 at 09:31 AM Reply With Quote
Ben, you still up in Newcastle?
Could do with some help re-designing my pedal linkages, because about 1mm of pedal travel = + 2,000 rpm. Seems a bit over sensitive.
Heard from Chris_R?
Mike
Ben_Copeland
posted on 30/7/05 at 09:39 AM Reply With Quote
I'm in newcastle, think chris is working. See what i can do
Ben
