locodude
| posted on 27/4/03 at 04:10 PM |
Air Filter mod
For those of you who showed an interest here is a picture of the modified std airbox. I know it looks a bit of a hotch-potch but it seems to work ok.
Well I think it does, it's just that the revs seem to run on a bit when you let off the throttle but it was doing this without the airbox so i
think it may just be a sticking slide, bearing in mind it's ages since the engines been run, at least 6 months if not more. Any ideas?
there are a couple more pics in my archive
[Edited on 27/4/03 by locodude]
steve faunch
| posted on 27/4/03 at 04:26 PM |
I had loads of bother getting my engine to run properly,iit also had been stood a while, the petrol in the carbs had evaporated leaving some sort of
scale blocking all the jets & making the needles stick
locodude
| posted on 27/4/03 at 05:18 PM |
If I get time next week I'll take the float bowls off and give all the jets a good clean, cheers mucka.
chrisg
| posted on 27/4/03 at 07:26 PM |
If you had any shame whatsoever you'd have put a big sheet of plastic over the whole jap abortion.
That poor crossflow *snif*
An englishman
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
locodude
| posted on 27/4/03 at 07:33 PM |
If you're coming over in the week you'll be able to see the mess that used to be no.1 big end. Poor little bugger!
Ninja
| posted on 27/4/03 at 07:39 PM |
I had a similar problem with the over run. Mine was due to having too stiff throttle cable. Try keeping pressure on the lever where the cable attaches
so that when you blip the throttle you push it straight back on to the stop. If that doesn't work it could also be the carbs out of balance.
locodude
| posted on 27/4/03 at 07:58 PM |
Cheers I'll try both, I was going to balance the carbs anyway.
Jasper
| posted on 28/4/03 at 08:17 PM |
Nice job mate .... looks pretty good.
