larrythelathe
| posted on 10/9/07 at 08:01 AM |
AFTERMARKET ECU
I would like to replace my zx9 ecu any one know of a company that does a aftermarket ecu?
Will megajolt work?
dan__wright
| posted on 10/9/07 at 08:11 AM |
mega jolt just does ignition, if you wanted to do fuel injection you would need mega squirt instead.
any particular reason you want to replace the ecu? if its for tuning the normal way to go is a power commander, dont hear of that many people
replacing bike ecus as they are generally a lot more flexible than a car and also handle a lot more.
FREE THE ROADSTER ONE…!!
Werner Van Loock
| posted on 10/9/07 at 08:22 AM |
VEMS ECU is also worth a look
www.vems.co.uk
http://www.clubstylus.be
larrythelathe
| posted on 10/9/07 at 08:34 AM |
cam sensor
i changed my engine from a c to e and the c ecu requires a sensor i don't have on the e engine. Nightmare
Dangle_kt
| posted on 10/9/07 at 09:18 AM |
Problem solved?
http://cgi.ebay.co.uk/KAWASAKI-ZX9R-ZX9-R-E2-ECU-CDI-IGNITION-UNIT_W0QQitemZ180156934807QQihZ008QQcategoryZ10464QQssPageNameZWDVWQQrdZ1QQcmdZViewItem<
br />
cheaper than aftermarket too
paulf
| posted on 10/9/07 at 11:22 AM |
Megajolt would not be suitable as the maximum revs it will work at is limited to about 10,000rpm by the ford edis module
Paul.
Will megajolt work?
clutch_kick
| posted on 10/9/07 at 11:30 AM |
Haltch E8 ECU.
ChrisGamlin
| posted on 10/9/07 at 01:48 PM |
An Emerald is probably one of the most commonly used in kit cars and has been used on some bike engines (Wyn (lsdweb) has one on his R1) so you may
find someone has a ZX9 base map that you could start off with. Without that you'll need a fair bit of dyno time to get it up and running
properly though (ie £££), and another issue you may have with any aftermarket is getting one that's compatible with your trigger wheel pattern
as certain ECUs need particular patterns to work.
Far easier to get an E model ECU / loom off Ebay Id think.
