FREAKYSTUFF
posted on 9/10/03 at 08:36 PM |
HAYABUSA POWER
Im planning to build a indy and put a busa lump in it thats the plan anyway. the one thing i'm bothered about is the donor car do i go for a
XR4x4 or XR4i , do i need a LSD, does ether one of these cars come with a LSD. is it best to go for discs all round...
NEED HELP big style....
any info on putting a munster bike engine in this car would be most welcome....
| posted on 9/10/03 at 08:52 PM |
i think discs all round is probably a good idea, all sierras from GLS upwards have rear discs, some have better ones (maybe vented? dunno). one of
those cars will also have an LSD, someone will confirm which! again, probably a good idea to do LSD so corners stay to plan!
all the best...
titch
| posted on 9/10/03 at 09:19 PM |
XR4X4'S ALL CAME WITH LSD'S
titch
| posted on 9/10/03 at 09:21 PM |
OH AND DON'T FORGET YOU'LL HAVE TO DRY SUMP THE BUSA ENGINE! MEGA BUCKS! £££££££££S.
loafersmate
| posted on 10/10/03 at 07:15 AM |
If you go for discs all round you'll have to fit twin master cylinders or a pressure limiting valve to stop the rear brakes having too much
effect....it's an SVA fail!! Go for a Blade or R1 tried and tested and no messing about with dry sump's etc etc As for LSD, I can only say
you can still go plenty quick on road and track without one  If you can drive that is
Ben
Simon
| posted on 10/10/03 at 08:41 AM |
I'm using R V8 with discs front / drums rear.
If that set up can stop a fully loaded 1.8 Sierra with a caravan, it'll do for my car!!
Simon
ChrisGamlin
| posted on 10/10/03 at 09:45 AM |
Regarding LSD, its not really a requirement on the road and not quite so critical in an IRS car as a live axled car when on track, but it will still
help enormously especially coming out of slow corners with the extra power that a 'busa gives you, so Id try and get one if possible.
Busas dont actually need dry sumping in most cases, there are several sprint / race cars with busas in that stiill use baffled wet sumps, including a
350bhp Dax turbo sprint car, its just that because of the extra outlay on the engine, its probably wise to protect the investment with a comparatively
cheap (compared to replacing the engine) dry sump.
[Edited on 10/10/03 by ChrisGamlin]
Jon Ison
| posted on 10/10/03 at 12:30 PM |
nice add at btm chris.........
ChrisGamlin
| posted on 10/10/03 at 03:28 PM |
Not sure if that was tongue in cheek Jon, but ive edited it to be more subtle and I'll take it off if it aint allowed. Lots of other people do
it on other forums, TBH I didnt even think to look to determine here was any different.
I only post on the BEC part of the site and its entirely BEC related, I dont make any wonga out of it anyway, just pushing a bit of pocket money the
way of my uncle as thanks for doing various bits n bobs for my Locost.
Chris
Jon Ison
| posted on 10/10/03 at 03:53 PM |
nah, was just n idle comment chris, not meant for you to take any offence what so ever...........
what did pee me off recently though, was when i advertised my spare blade engine recently at a very reasanable price and some one (nameless) posed as
a "private" buyer after it, all they wanted was to add there "£££'s" to it and sell it on, rather the man in the street
had it if u know what i mean...........
ChrisGamlin
| posted on 10/10/03 at 04:10 PM |
Hmm I assume you're referring to one of the kit car manufacturing fraternity there, tis a bit cheeky them doing that and I know exactly what you
mean, just keeps prices artificially high if they do that to all the engines.
I dont suppose you have / know of a 919 blade crank laying about anywhere do you? I took apart my old 919 that I blew up last year after a sump plug
AWOL incident, and its run a big end and knackered the crank journal as expected. My current engine is also in need of a crank now tho, as its
stripped the drive gear that goes onto the clutch at Donnington a couple of weeks ago. So now have two otherwise perfectly useable 919 engines
sitting in my garage apart from both having crank issues. The galling part is that the drive gear on the big-ended crank is perfect
Chris
Jon Ison
| posted on 10/10/03 at 04:17 PM |
only one i know of is the one that blew in the GT1, but that was crank too, next time i speak to MK, weekend prob i will enquire as it can be an
alladins cave there at times...........
ChrisGamlin
| posted on 10/10/03 at 04:25 PM |
Cheers, much appreciated
FREAKYSTUFF
| posted on 10/10/03 at 04:58 PM |
Sorted...XR4X4 it is,
Im only bothered about 0-60 time (0-100 really).. not top end speed, wats the best diff to use 3.88..3.90 ect.
and this baffling i take it this is cos the engine is turned 90deg. who's best to talk to about that...
Jim
| posted on 11/10/03 at 03:53 PM |
I SVA tested my Indy Blade without twin master cylinders or a limiting valve. Passed the brake test with flying colours. It was an XR4x4 donor
car
Jim
FREAKYSTUFF
| posted on 11/10/03 at 04:13 PM |
Jim did you use the rest of the car as a donor, eg prop...diff...ect
and did you put discs all round (not sure wat 4x4 has all round).
Russ
Jim
| posted on 13/10/03 at 08:15 PM |
I used the prop, diff etc. Yes discs all round. The car i had was a C Reg XR4x4 2.8 i.
Somehow I as got a age realted plate!!
Were exactly are you in Rotherham 'cos you can come and have a look if you want. I live very close to Chapeltown, sheffield
Jim
[Edited on 13/10/03 by Jim]
Grant
| posted on 14/10/03 at 08:34 AM |
BEC engines
We've got a lot of turbo bikes here in America (relative to the UK, I am told), so I thought I'd chime in.
Turbo GSXR1000:
http://www.suzukihayabusa.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=19;t=000022
This is the only turbo 1000 I've heard of. Hopefully it will prove to be as strong as the Busa motor.
Turbo Busa:
http://www.suzukihayabusa.org/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=20;t=000223
Yes, its insane what they are getting out of the Busa motors. Also, taller 5th and 6th gears are available. A big plus if you've got a turbo,
since you'll hit the top of your gearing quickly.
Gixxer 1k:
From what I've seen these dyno about 10-12hp more than the R1s. Supposedly they are lighter & shorter than the Busa engine. Maybe a good
alternative? I guess they aren't as proven.
R1 vs. GSXR1000 vs. 954 (with mufflers)
http://www.rooracing.com/Comparisondyno.JPG
I'd be much more concerned about hp/drag than hp/weight. Maybe its just the tracks around here, but there aren't many corners I'm
not coming out of at 70-90mph in my Toyota Supra. One would think the aerodynamics of the GT1 would give it an advantage over a Sylva, possibly making
up for a worse chassis (if it is indeed worse, I have no idea).
[Edited on 14/10/03 by Grant]
FREAKYSTUFF
| posted on 14/10/03 at 02:34 PM |
So...... 575bhp BUSA in an INDY
yep... i could see my licence lasting about 5 mins (if i was lucky)
Simon
| posted on 15/10/03 at 04:13 PM |
Freaky
You could always build a Tiger with two turbo's bike engines and 4wd.
Simon
FREAKYSTUFF
| posted on 15/10/03 at 06:07 PM |
I WISH...............
