Colnago_Man
| posted on 9/1/08 at 02:09 PM |
Wobbly Sprocket Adapter
After buying a second hand engine that had previously been in a BEC I've notice there is a bit of play in the spocket adapter. The drive shaft
has no play in it and the bolt is fully tight.
Is it usually to have some play in the adapter or do I need to remove it and get some suitable washers under it?
Guinness
| posted on 9/1/08 at 02:24 PM |
Shouldn't wobble mate. Get a washer on it.
Mike
Howlor
| posted on 9/1/08 at 02:35 PM |
I had to put a thin shim under mind to ansure it pulled up tight.
zxrlocost
| posted on 9/1/08 at 02:48 PM |
as above
it shouldnt wobble
ta chris
Coose
| posted on 9/1/08 at 03:29 PM |
The adaptor is probably slightly shorter that the splines to allow the fitting of a sprocket tab washer.
Spin 'er off Well...
