andy o
| posted on 17/1/08 at 08:13 PM |
bit of a long shot
i have a bailey-morris prop,it 1500mm long with a sierra flange one end and a flange to suit a prop adaptor at the other,it has a sliding section and
centre bearing it is new and unused.
so if theres anyone whos about to order a prop as above get in touch and we could
do a deal as i need one 300mm shorter and with an english axle flange.
thanks andy
paulf
| posted on 17/1/08 at 10:09 PM |
If the axle has the large size flange fitted to most then it is the same as the Sierra flange in which case you could just get it
shortened,alternatively if you have the smaller flange as was fitted to 1100 escorts then you could swap the axle flange with a little care as i had
to flanges are available you just need to be carefull with the preload.
Paul.
