bob tatt
| posted on 17/2/08 at 05:22 PM |
fireblade clutch cable
need to know what cable to use as mine snaped today twenty miles from home so a nice drive turned into a ride on a recovery truck the engine is in a
mk indy need to get this fixed pronto as ive got plans next weeek end for a big drive any part numbers or even if any one has one i can exchange for
bear tokens will be well received thanks in advance rob
Jon Ison
| posted on 17/2/08 at 05:44 PM |
I just went to motor factors and chose one that suited my pedal and the blade lever.
But the reason I have replied is when you do get sorted fit a stop on your pedal, (if you don't already have one) the lack of one is often the
cause of clutch cable problems.
Recovery truck for a broken clutch cable in a BEC ? Shame on you......
bob tatt
| posted on 17/2/08 at 06:00 PM |
no movement cant get it off the line with no clutch still it was a lot warmer in the van anyway.
