dan__wright
| posted on 10/3/08 at 12:28 PM |
BEC Crank Breathers.
im fitting the original zx10r air box on my engine (turned 180) but to get it to fit i had to blank off one of the breather connectors on the base
plate.
should i just stick filters on the breathers and blank them on the air box or should it put another connector on the air box and do it that way?
[Edited on 10/3/08 by dan__wright]
FREE THE ROADSTER ONE…!!
| posted on 10/3/08 at 12:50 PM |
It's not going to make a huge difference.
A lot of breathers get left open to atmospheric without problem... A breather filter would be a cautious approach. Making a new connector on the
airbox is probably a bit anal and risks getting swarf and other grot in the airbox which will then go into your engine when you run it ....
PAUL FISHER
| posted on 10/3/08 at 02:10 PM |
Ive run a pipe from the crankcase to a oil catch tank on the bulk head,just keeps your engine bay area a bit cleaner,as the breather filters tend to
cover your engine in a fine oil mist,you can then just drain the catch tank every service.
