Author: Subject: pressurizing carbs
oadamo
posted on 19/3/08 at 10:49 PM Reply With Quote
pressurizing carbs
hi
has anyone got any info on pressurizing bike carbs for a turbo.
thanks adam
caber
posted on 19/3/08 at 11:06 PM Reply With Quote
Sounds iffy likely to blow seals in the carbs that are normally operating under partial vacuum. Turbos are usually used with injection systems. Superchargers can be used with the carbs before the supercharger.
Caber
Moorron
posted on 19/3/08 at 11:39 PM Reply With Quote
http://www.turbo-bike.net/
on the left side is a section on it.
Sorry about my spelling, im an engineer and only work in numbers.
worX
posted on 20/3/08 at 06:09 AM Reply With Quote
As above, but I believe it's a bit different for a Blade engine...
posted on 20/3/08 at 10:35 AM Reply With Quote
Why can't you have a suck-through system on a turbo? Leakly-spindle syndrome on a supercharged system can be sorted that way.....
Mr Whippy
posted on 20/3/08 at 11:35 AM Reply With Quote
I got round leaking spindles by taking out the original bush and replacing it with one I made. All I did was smear a tiny bit of grease in the spindle (removed from the carb) and wrapped thread tightly over it till it was the right diameter for the bush hole. Then poured superglue on the thread and rubbed it in. The new bush is then just sanded smooth on the outside and fitted into the carb, fixed in place with a drop more glue. Perfect fit and absolutely no air leakage
