Author: Subject: R1 sproket sizes?
adithorp
posted on 3/5/08 at 11:50 AM Reply With Quote
R1 sproket sizes?
Does anybody know what size (No of teeth) sprokets are fitted as standard on an '06 R1? I've been through the service manual and it's not there!
Also...Any ideas what the outside diameter (or roll out circumference) is on the rear tyre; 190/50/r17?
It's to help me work out the correction I need for my speedo. I've got a "yellow box" healer and it works by correcting the % difference between original ratio and current one. I can correct at SVA on % difference between actual and indicated speeds but I'd like to get somewhere close first.
adrian
adithorp
posted on 3/5/08 at 01:58 PM Reply With Quote
Freelander diff' so 3.21 (I think) and 205/50/15 tyres.
adrian
grub
posted on 3/5/08 at 03:05 PM Reply With Quote
yeh i was just going to say that my self but ya beat me to it chris
adithorp
posted on 3/5/08 at 03:58 PM Reply With Quote
...and 0-60 in first!
Well 18 months ago I didn't know as much as I do now and that diff' was recommended to me (i'm not the only one). Don't think it'll hit the limiter in top very often! The Fury isn't quite the brick that a Seven is though.
-20% should be ok for SVA then. Thanks for that.
adrian
Coose
posted on 4/5/08 at 02:44 PM Reply With Quote
In which case you can fit proper sized wheels (13" )!
[Edited on 4/5/08 by Coose]
Spin 'er off Well...
adithorp
posted on 4/5/08 at 07:08 PM Reply With Quote
There's a set of CXR 13" rims with R888's on (205/60/13rears) waiting to go on post SVA. They're a bit wider ET so might not pass with them. The 15's should slow things down a slight bit while I get used to it (and have more tread for the current climate).
adrian
Coose
posted on 4/5/08 at 07:51 PM Reply With Quote
Good call!
There's nowt wrong with R888s, even in the damp!
