Author: Subject: What thread/location 'Busa oil pressure sensor?
sucksqueezebangblow
posted on 8/5/08 at 11:30 AM Reply With Quote
Hi All,
I'm pretty sure the standard 'Busa oil pressure sensor is in fact a pressure switch. I could be wrong! Is it needed for the engine to operate correctly or can it be disposed of?
Assuming I keep it what are the options for fitting a pressure sensor? T-piece in the original pressure switch hole? elswhere? Also does anyone know what the diameter and thread is of the original pressure switch hole?
Yours, Clive.
richard thomas
posted on 8/5/08 at 12:27 PM Reply With Quote
Yes, the standard one is a switch, I think it operates at around 6psi. I put a T-piece in mine, ran a take off for a mechanical pressure gauge from it. Can't remember what size thread it was though...
I was advised that if fitting an electrical oil pressure sensor, don't mount it directly to the block, mount it remotely to stop it vibrating to death.
Jason Fletcher
posted on 8/5/08 at 12:30 PM Reply With Quote
Clive
You are right, the standard thing is just a switch and it is not linked to the ECU at all. I rigged mine to the oil light on a SPA dash I am using but if I never had the dash then I would certainly not dispose of it. How about running an ultra bright LED from it? You will then know immediately if there’s a drop in oil pressure. As for fitting an oil pressure gauge and sender, there’s a M14 plug by the O.P switch and this is what Suzuki connect an O.P sender to. Get a gauge and sender, find out what thread it uses and phone Merlin up and they will sell you an adaptor to take from say 1/8 NPT if that’s what the sender is to M14.
Jason
sucksqueezebangblow
posted on 9/5/08 at 08:24 AM Reply With Quote
Excellent advice, thanks Richard, Jason. Looks like the answer is the M40 adapter with a remote sensor. I like the ultrabright LED idea too. Priced them up in Maplin, all of £1.37p for LED, holder and pull down resistor!!
Yours, Clive.
Jason Fletcher
posted on 9/5/08 at 08:30 AM Reply With Quote
I'd go with the M14 adaptor if I were you
10mm LED with the proper mounting gizmo would be cool.
Jason
sucksqueezebangblow
posted on 9/5/08 at 04:18 PM Reply With Quote
Not sure whether I had the bolt-action sniper rifle or the moterway in mind! M40 would be rather large!!
Got the LED and all today so will do some experimenting this weekend. If you see a small mushroom cloud over Iver you will know I got the voltages wrong!
sucksqueezebangblow
posted on 12/5/08 at 10:36 AM Reply With Quote
Hi Jason,
I found the plug and measured it. 15.92mm across the threads and 1.5mm pitch. I'm not going mad am I, as I think that makes it an M16? My engines a '99 so they must have changed the plug size in later engines?
Yours, Clive.
Jason Fletcher
posted on 12/5/08 at 08:23 PM Reply With Quote
Clive
you are right, it is a M16 thread.
I got all muddled up because I got sent me the wrong one which was a M14 but it was changed to a M16 which is what the invoice says.
Sorry!
Jason
sucksqueezebangblow
posted on 13/5/08 at 08:32 AM Reply With Quote
No problem Jason, I'm really grateful for the tip. It's the perfect solution so many thanks!!!
