Author: Subject: R1 fault code help
andy o
posted on 10/5/08 at 06:22 PM Reply With Quote
R1 fault code help
hi all
trying to start r1 5vy
fuel pump not working and following codes 14/23/30
anyone know what they are or where to find them in service manual
thanks andy
andy o
posted on 10/5/08 at 06:49 PM Reply With Quote
tried that,no brum
do you need to to reset the clocks and if so how?
andy o
posted on 10/5/08 at 06:54 PM Reply With Quote
yes still scrolls the 3 codes
tks
posted on 10/5/08 at 07:00 PM Reply With Quote
reset the mcu....
and see if they come back...
if they do you know what to solve..
its an easy one..
Tks
andy o
posted on 10/5/08 at 07:14 PM Reply With Quote
hi,tried tilt sensor in every posistion and code still there.will try direct wire to pump tomorrow.
andy o
posted on 10/5/08 at 07:16 PM Reply With Quote
what an mcu and how do i reset it
andy o
posted on 10/5/08 at 07:37 PM Reply With Quote
thanks for that ,i'll give it a go
mal at yorkshire engines supplied the loom and ecu so should be ok.will let you know how we get on
Davey D
posted on 10/5/08 at 08:20 PM Reply With Quote
when i had cod 30 on mine i had to put the tilt sensor the correct way up, then turn the ignition off, and back on.. the code would then go
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 10/5/08 at 09:07 PM Reply With Quote
I had to do the same as ^^^^^^^too
[Edited on 10/5/08 by CRAIGR]
ko_racer
posted on 11/5/08 at 11:44 AM Reply With Quote
The tilt sensor is latching so won't reset until you switch the ignition off and back on again.
