Author: Subject: Smiths telemetrix speedo jumping around, will a gear indicator work??
MK9R
posted on 16/7/08 at 07:11 AM Reply With Quote
I have a smiths telemetrix speedo, and the needle does jump around a bit (+-10mph), will this mean a gear idicator will not work??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Flamez
posted on 16/7/08 at 07:23 AM Reply With Quote
just out of interest do you have a speedo healer fitted?
MK9R
posted on 16/7/08 at 07:28 AM Reply With Quote
whats one of those????? I bought the car with it all fitted so no idea. I assume the healer just smooths out the spikes obtained from the pulses??
Cheers Austen
RGB car number 9
www.trackace.co.uk
mackei23b
posted on 16/7/08 at 07:43 AM Reply With Quote
Hi Austin
The Speedo healer, when used is placed between the speed sensor and the speedo. It can multiply or divide the number of pulses from the sensor to calibrate the speedo.
In your case, If the telemtrix speedo is electronic I am sure it already has a calibration cuircuit built in so you should not have the need of a speedo healer.
To answer your initial question, as long as you are getting a consistent pulse from your speedo sensor, a gear indicator should work perfectly. It may be worth checking the sensor set up just to check all is OK. Or find someone with an ocilliscope to double check the sendor pulse is constant.
Ian
[Edited on 16/7/08 by mackei23b]
MK9R
posted on 16/7/08 at 07:45 AM Reply With Quote
The bracket holding the sensor next to the prop isn't the best thing i've seen, i suspect it is probably vibrating, causing the occasional loss of pick up. I just wondered how good these telemetrix speedo's are, i.e. do they jump around a bit any way??
Cheers Austen
RGB car number 9
www.trackace.co.uk
DRC INDY 7
posted on 16/7/08 at 02:02 PM Reply With Quote
It could be a poor earth had that one before causes the needle to jump around
Puddle Dodgers Club
